Radiator options
There is NO "cheap alternative", sorry if that si not what you want to hear. There are alternatives obviously, but whatever you do is NOT going to be cheap.
Ours was recored 12 years ago, at it was $680 then.
I considered a HE radiator, which is the thinny unit, but kept with the thicker one. The HE unit is a direct fit, as such, if you find a s/h unit, although some bracket alteration MAY be required, as some of the Pre HE had the brackets for the oil cooler attached to the radiator lower plate, whereas the HE had the brackets attached to the lower support panel. I did that alteration to ours, makes getting the radiator out much easier.
Sometimes you see them appear on Fleabay.
I ended up buying a used one for $400 off a local shop that deal with English cars. Not really excited but happy to be moving on. Alot of calling and searching.
If a generic say 6.0L ford or GM radiator which retails new for $150 could be adapted that would be the future solution. My reading suggests they really haven't changed all that much. May be a good business for someone in the know.
Received 10,990 Likes
You can use a generic single pass radiator if you reconfigure the plumbing to a single upper radiator hose.
