Radiator Removal SIII
There is one in the shop manual which you can download from the sticky page. Please do a write up when you do the work. Especially if you are going to do the thermostat and water pump while at it. Also if you can post the exact make and model of the new shiny one, it would help others, ie me, when I need to do it next year.
I am not sure of the differences between my lumped S2 chevy radiator and your presumably stock S3.
However, I have pulled the radiator out of my car several times.
There are four small bolts holding the radiator upper support. Remove those, the hoses, and anything that is mounted to the radiator and it should just lift out.
If you want more room from the hood, you can remove a single small bolt that limits the hoods maximum travel.
This would allow the hood to go almost completely vertical, the springs should hold it there and you will have plenty of space to work around the radiator.
The Rad is from Rockauto, made by Liland Global (China probably). Part number is 33AA. Cost $145 US ($175 Cad). Looks very well put together with clean welds. I hope it fits!
See link: https://www.rockauto.com/en/moreinfo...178096&jsn=923
JA0342787
05-08-2014 09:24 AM
