rear defroster/winshield washer fluid
when i had my windows tinted, the wires that attach to each side of the rear window came un done. what is the best way to reattach and make operable again?
also my washer fluid doesntshoot out? im not even hearing any noise when i press the device to shoot the fluid. where should i begin
Received 10,881 Likes
Wires: Never had to fix one before, nor even taken close notice, but I think they're just soldered on. Others will chime in
Washers: Is the pump plugged in? It's at the bottom of the reservoir
So jump the pump and see if it runs. If it does, go to the back of the wiper switch and see if the circuit closes when you pull it towards the spray position.
No relay.
The light green wire to the pump should have 12v from fuse #11 with the key "on". The light green/black wire should show "ground" when the washer button is pushed.
If that checks out OK then, yes, you have a dead pump
aholbro1
08-05-2021 05:02 AM
al_roethlisberger
09-11-2015 10:04 PM
Wes Steenrod
09-06-2015 06:52 PM
Tar
09-06-2015 11:24 AM
