Rear Door Ashtray removal
Sorry, forgot you request in red ink.
OK, obviously you have to take off the door panel, but first make sure the window is up, and then tape it up so it can't drop down. Then, when you unbolt the lift motor, you can slide the motor arm off the door glass easily, and not get annoyed with the window trying to drop on your fingers. Rear window lift is just one arm onto a channel on the glass; fronts have two arms as glass is much wider.
These door lifter motors are hefty beasts, far heavier than modern stuff.
99xk8guy
06-05-2023 06:28 AM
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
davidladewig
09-03-2015 06:32 PM
