Rear outer hub seal
Rear outer hub seal
Rear outer hub seal is C24789, has anyone used the SKF replacement 29208? Seems close for fit in the hub (outer dimension) but it feels almost loose on the axle sealing surface (inner dimension). I guess it might squeeze in a little after being pressed into the hub but idk? When offered onto the axle not mounted, it pretty much just falls into place with no coaxing. Ideas?
