Rear shock absorber installation trivia
Received 10,988 Likes
A couple tidbits that might help someone installing rear shocks, especially a first timer.
Pic 1
It can be a little tricky to install the lower shaft that runs thru the control arm and thru the bottom eyes of both shocks. Take the shaft to your bench grinder and make a small bevel on the shoulder of the shaft. This allows it to pass into the shock eyes more easily
Pic 2
Inside the upper eye of each shock is this bushing, oft mentioned. Make sure to look for 'em and transfer them to your new shocks. If you don't install them you'll have one helluva rattle
Pic 3
The upper mounting bolts should be installed from the inboard side to the outboard side....so that the nuts are on the outside of the cage. Reversing this...only possible if the cage is out of the car....will mean that you can't get the bolts out once the cage is installed. Ask me how I know
Pic 1
Pic 2
Pic 3
The following 6 users liked this post by Doug:
Grant Francis (01-09-2021),
Greg in France (01-09-2021),
Jag7651 (01-09-2021),
LnrB (01-09-2021),
o1xjr (01-09-2021),
and 1 others liked this post.
The following 2 users liked this post by LT1 jaguar:
o1xjr (01-09-2021)
Doug (01-09-2021),
The following 2 users liked this post by Robert Laughton:
Doug (01-10-2021),
I slid the bolts out as far as possible and then took a Sawz-All to 'em !
The following 2 users liked this post by Doug:
Greg in France (01-10-2021)
sbreeden
06-21-2012 01:15 PM
