Rear turn signals
Hello, I have a 1989 XJ6 and are having problems with the right turn signal. when i turn the right turn signal on everything is fine ,till i step on the brakes, the indicator on the dash blinks faster , the front right turn signals operate great, but the rear signals quit ( no blinking) I have changed all the bulbs with the correct ones, checked the grounds for contact, Does anyone have any ideas where to go from here, Also what is the difference between a Rear lamp Relay Module and a Lamp Control Monitor. Thanks
This section is for the XJ6 until 1987.
