Rear window defroster inoperative
Received 10,916 Likes
If you have a test light or meter you can check for voltage at the plug to the defroster grid. There are actually two plugs, left and right. One gets 12 volts, the other goes to ground. I can't remember which is which. But, if neither gets 12volts with the switch on, post back.
If you DO get 12 volts at the grid plug then you've probably lost the ground. Might be as simple as the wire being disconnected.
jagnation89
10-17-2015 01:48 PM
