Rear windows won't operate
Dave,
Thanks for your post, I Iwas finally able to get to the rear window switches cleaned which were the problem. I did not realize the rear switches, would be my issue but as they are tied to the front console rear window switches, (Right) I also learned how to remove the rear door panel, the next time I have to go into the door.
Thanks again
Jim
Thanks again
Jim
The following 2 users liked this post by JimJam:
Doug (08-29-2020),
yachtmanbuttson (09-02-2020)
you welcome Jim. sometimes I hit the spot, and I have experience with that rear center console section.
in my car I installed the rear center section from a Vanden Plas XJ-6, it is a lot nicer with another cig lighter and chromed ashtray. Because Vanden Plas interiors don't come in Buiscuit color, I recovered it with Biscuit color vinyl.
The wiring for the extra cig lighter is already there, taped over in non-Vanden Plas XJ-6. David at Everyday XJ supplied the missing extension wiring harness section so it was an easy connect.It mounts the same way as the short section, with the two screws and two pins. Alignment is identical.
yes, José, Josey, Josué, Jesús, Joshua, all come from the same roots, 11th century. 12 thousand years ago. Gregory is the literature expert here.
