Refinishing Manifold Heat Shield - '87 XJ6 VDP
removal of heat shield
I am having trouble uploading pictures from my phone.
Look at the bottom edge of the shield, towards the left side, There is a thick rubber hose clamped to the shield, the hose is coming from the air valve. The clamp must be separated from the shield and then the shield is freed.
you'll need a 11mm open wrench, and a small ratchet with an 11mm socket to loosen the clamp's bolt and nut. Then you can undo the 13mm bolt on top and the large bolt needs a 22mm socket with a large ratchet and extension.
I used stainless steel washers under the top bolts on reassembly to avoid scratching the Jet Hot Sterling coating with the bolt heads.
al_roethlisberger
06-10-2014 04:04 PM
