Relais question series 1
The one mounted on the dashboard is, as I recall, main ignition relay. The other two I haven't seen on my car, but I would guess they might be for electric windows. That is of course if yours are electric.
I can check with the manual tomorrow when I get to the garage and let you know.
This is the only information about relays that the manual mentions. It seems that the one on the left-hand screen pillar is an alternator relay. On the opposite side should be a starter solenoid switch relay. (pic related)
I couldn't find any info on the third one, but as I mentioned I remember it to be a main ignition relay also referred to as a "ignition protection relay".
Hope it helps, if you're interested I can send you also a full wiring diagram from the service manual.
