Remote Starter
I installed an old bulldog remote starter in an ‘86 Lincoln back when I had next to no mechanical or electrical experience. It’s pretty simple- the unit is basically a relay that connects the 12v constant wire that goes to ignition with the wire to the starter relay. You can also tie that in to a door lock wire, trunk release, lights (if you want them to blink when you press it) etc.
Don’t see any reason it wouldn’t work for a fuel injected XJ6 (carbs might be tricky unless you had an electric fuel pump, since you wouldn’t have a way to prime it).
