Remove Front Valence?
Just got a new front valence for my xj6. The four front horizontal bolts holding the old one on removed easily. But there are two additional bolts vertical on each side. For the life of me I cannot figure out how I can access the bolts to remove them. The heads are behind some kind of bulkhead. Any advice?
Thanks.
Thanks.
Surely it bolts to the wings on each side, plus to the cross-member at the bottom. When I replaced mine in the early 90s, I spaced out the valance from the cross member by inserting some stainless steel washers so as to make a gap between valance and cross-member. Leaves and muck accumulate in this area and salty water can lie there so with a gap at least the water drains away. You still have to vacuum-out the crud every so often, though !
you welcome. It helps to spray Rust Blaster penetrant for a few days before attempting to loosen those bolts. They were torqued tight at the factory.
Also you need to caulk the seam at the front between the valance panel and each wing where they join so no water gets between them. I used black silicone caulking cleaning the excess with paint thinner.
LT1 jaguar (06-18-2019)
Received 2,399 Likes
New valence installed
Hidden rust under old valence
Old valence
So that’s done. On my car the bolts were all 1/2 inch. The U joint was key on both sides. The passenger side bolts were quite straightforward. However the driver’s side bolts require removal of both the washer fluid reservoir and coolant overflow container (?) to reach the bolts. This was a good opportunity to clean all the dirt that had accumulated behind both. Also when I removed the valence (which had some rust) I found more behind it on the cross piece that holds the radiator. I ground everything off and primed and painted and did a thorough cleaning of the wheel wells and front of the car including refreshing the rubberized rock shield.
The following 2 users liked this post by Gismo:
Andy Paine (07-07-2019),
Daf11e (06-28-2019)
The following 3 users liked this post by Gismo:
Received 9,267 Likes
The photos show the devastation caused by bolting up the valance to the bottom of the cross member. My car was OK but it wasn't all that old when I replaced the front valance. It is well worth spacing out the valance from the cross member to let water flow out unhindered. Also make sure this area is vac'd out regularly.
this valance design started in the 1960s. My 1965 S type has it too, except it is only bolted to the front member, but not to the wings, a lot easier to remove with only 5 flathead screws and fender washers. Not a structural part like in the XJ, it is just a finishing under-bumper cover to hide the ugly front member fascia.
Is it structural? If so feels pretty flimsy! Thanks for all your advice. I made sure to caulk as you suggested. Now of course my ignition light suddenly started staying on. I haven’t driven it in two weeks and only drove it at low rpms yesterday. I turned the key on several times to get power to check that the washer pumps were working properly while replacing the washer reservoir. Could it just be a low battery? It started and ran fine despite the light staying on.
