removing dash
Received 10,871 Likes
Jose is right; the service manual is your best bet.
Typing out (or even remembering) *every* step is a bit much but, in a very abbreviated nutshell....
- remove plastic pieces at each end of dash
- remove padded top piece (screws under the edge...look from below). There's an air tube for the cabin temp sensor that you'll have to disconnect
- remove center air outlet (it simply pulls off)
- disconnect wiring ....there are mid-connectors in the harness. The instruments and a small amount of the wiring stays with the dash as you remove it.
- remove nuts holding dash in place; remove dash
In a nut shell..
Remove top dash pad.
removed block finisher panels from sides (a pillars) and bottoms (knee area)
Removed Gauges
Remove glove box door and insert
Remove HVAC control panel and gear selector panel
Remove information center, switch panel / pencil shelf
Remove HVAC center register
Unbolt defroster diverters from dash frame
Unbolt dash metal panel and frame from the HVAC box, top side struts (7/16 bolts) and A pillar side struts (1/2 nuts)
Disconnect map light and HVAC temp sensor.
After all that and a few things I probably forgot the whole metal frame with the wood attached can be removed. After it's out, place it wood side down and remove the many small Philips heads screws that holds the wood on to the metal frame. Upon reinstallation of the new wood test the location and alignment before you install all screws and make sure the HVAC register and gauges fit properly.
When you're done with this very labor intensive process you will wonder and be amazed how much went into assembling these vehicles.
Removed Gauges
Good tip... It would be best to remove the gauges to prevent damage during refinishing and/or removal. I suppose it doesn't matter if you remove the gauges after the metal panel is in place or while it's still in the car. My experience was the large gauges are easy to disconnect, remove first and set aside for safe keeping, the smaller gauges with their tiny hold down nuts would be far easier to document the wiring and then remove with the complete panel out.
1964Daimler
09-09-2015 11:28 AM
