Removing entire center console question...
Hi guys,
I'm planning on taking out the center console to patch my transmission tunnel, and add some modern sound-proofing material. I can't seem to figure out how to remove the sucker.
I've removed the "slope" panel, which has the hole for the shifter as well as the window switches etc and the little lid & tray. I also removed a pair of screws that are towards the back seat.
I have removed the driver's seat for easier access -- what other screws am I missing? Should the entire unit just pull up, or are there more bolts that are obscured by foam insulation/carpet?
Thanks in advance!
Tyler
Thanks in advance!
Tyler
From memory there are two screws up by where the radio is, but still in the vertical plane, the rear ashtray/window switch bit of trim, and I think (but I'm not sure) that you should be able to pull it up from the back and slide it out? Last did this years ago so I'm a bit rusty on the operation.
there are two chromed screws at the rear edge of the center console, and once you remove the plastic center tray's 6 screws, (you first remove the hinged cover before removing the plastic tray), there are four more screws below over two brackets in the transmission tunnel.
The radio has to come out first, and for the radio to come out first, you have to remove the a/c controls panels first. Then comes the disconnection of the rear window switch plugs which should be first too.
the top center section panel, where the trip computer is, has to come out first, there are two screws at the bottom edge of that panel, and there are two screws to remove behind the panel where the computer is, those have to be removed first.
HINT: start by removing the ski slope panel, then the a/c controls panel, then the radio, then the vertical trip computer panel, so you need to go front to back. Everything is done first.
the way I did mine, I labeled everything as I disconnected each wire with little white labels and clear tape over them because there are so many wires and other things to disconnect and later put back, you will never remember where all of them go, even if you are Einstein.
Remember the Law of Relativity: "If anything is going to go wrong, it will".
If you want to make the job easier, remove the front seats first. You will find out why when you're removing everything else first.
thanks guys for the help -- yep, managed to get it out. it's a HUGE pain in the ***. I'd have to say its one of the most labor intensive jobs you can do in the cab (aside from removing the dash).
center bucket, ski slope, dash center cluster, radio all have to go, or be tweaked to access the final 4 bolts that hold the center console assembly to the side molding trim. hopefully won't have to do that job ever again!
clubairth1
29
05-10-2024 12:57 PM
280zx-turbo
09-10-2015 06:29 AM
1964Daimler
09-09-2015 11:28 AM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
