Removing Water Pump Pulley
Just bought a NOS water pump and the pulley shaft for the viscious fan clutch is just a bit too small. So I have to swap over the old pulley shaft to the new pump. Anyone know how to best remove the pulleys from the pump? Does that big nut unscrew and it's press fit on?
Thanks, Bill
Thanks, Bill
Memory,
That big HEX is a cast part of the pulley, NOT a nut, thus enabling you to hold that pulley whilst tightening, or undoing, the centre bolt of the clutch assembly.
I have never tried to remove that pulley, but a specific puller, or press with GOOD placed pates, to press the shaft out of the pulley will be the only way.
What part is too small, the pulley itself, or something else??
Well, my ideal situation at this point would be to swap over pulleys from one pump to the other. But I'm afraid that I or a machine shop would bugger up the pulley. Guesss I'll keep an eye out for either a matching SII pump or a fan clutch that will fit this other pump (whatever it is). It is marked C45161/R on the box which shows in the parts manual as for a 4.2 8L.25469 and greater and my engine is 8L.40403
But who knows what some PO did in parts swapping.
Received 2,399 Likes
That would be my voter. E fans are great. My lump thrives on it's pair.
And, Is there not a great risk that the shaft from the old pump will not fit the new pump?
You are very fortunate in getting a NOS pump! Messing with it seems highly risky. End up with a bad old unit and a screwed up new unit!!!
Carl
Carl
Yes, I agree, one wouldn't know until pulleys are off if there are swappable. Not my most favorite option. I just didn't want to make too many changes to the cooling system at once. I've already changed out the stock radiator with an aluminum one. And I'm going with an after market A/C condenser. E fans only is another BIG step. Do I install inside the shroud as a puller fan; outside as pusher fans; will my stock Lucas alternator support that current draw; will my battery support it? I would hate to do all that work and find out it doesn't keep the engine cool.
Received 10,989 Likes
Another *possible* option would be a later Series III pump, clutch, and fan. The type that uses the 4-bolt clutch.
Haven't researched the viability, though. There might be snags.
Alternators and e-fans: Series 1-2-3 XJ6s typically had alternators that were barely adequate to begin with in terms of amperage.
Well, toss that pillow again!!!
Johnscars markets a bracket to install a popular AC Delco alternator with lots of amp capacity. A bit pricey. And add the Efan package and it isn't cheap. But, so efficient.
The fan/fans go best as "pullers" in a a shroud behind the radiator.
Source from the wrecking yard or after market. Just make some measurements as to the space in your car and compare to what seems similar.
But, on balance, just get a pump that fits. Check out Doug's idea.
The short way home!!!! Not always the way I go, though!!!
Son calls it making a job in to a project!!! He won't admit to doing the same!!!! A very talented guy that goes into many fields...
Carl
Carl
Luke5324
12-05-2015 01:50 PM
Timothy
05-16-2012 07:14 PM
AntixSD
04-03-2010 07:40 AM
