Replace Wiper Motor
Replace Wiper Motor
I finally have all windows sunroof working, also engine is running smooth as silk. I was just about to take the Jag out for it's first ride in 6 years and i went to turn on the windshield wipers and nothing. I probably shouldn't take it out in the rain anyway.....lol, but this being my first ride in it I was so bummmed. Okay now for the question, WHERE IS THE WIPER MOTOR???? ...lol, the schematics I have show it on the passanger side but is it behind the glovebox or under the dash?
Hopefully it will quit raining this week....It is a 84 xj6
OK, I reckon yours is LHD.
I have NO IDEA on LHD, but on RHD it is tucked in the body aperture alongside the battery. Later models here had a plastic cover over it, but it is there, same as the S2 cars.
Maybe LHD have it in the same side??, or it may be on the RH side. Someone in your part of the globe will answer it soon.
alyree (10-12-2011)
HI Robert..
As Grant says, it's beside the battery, tucked into the body just a bit..
But chances are slim it's the motor itself... A majority of the time it's the wiper switch, and could be as simple as a fuse... Can't remember which one off the top of my head, but there is a fuse for the wiper motor. Check the illustration on the schuttle panel door...
There is also a ground on the wiper motor. I've seen that come loose or break, so check it too...
The way I check the motors here while on the car is I have the female part of the wiring harness off of another car... So I disconnect it from the questionable motor, connect the loose wiring harness, and jump straight to a battery... Like I say, the majority of the time the motors are good, unless they've been subject to a lot of water.
David
EverydayXJ.com
David
EverydayXJ.com
Guys thanks very much for the info, it was very useful. Replaced the fuse and checked to make sure I was getting power to the motor and I was but still no wipers. I was standing there and it hit me, the car has been sitting for a while so I took a hammer to it and I swear it started working. Now I just need a new driver side wiper arm, it is stripped and moves when and where it wants too. David do you have one?
It could be either be the wheel box cog that is stripped or worn out, or the splines on the box spindle. This is nothing to do with the wiper arm which fits onto the wheel box spindle. Of course the spliines on the wiper arm itself could be stripped, which is an easy fix - you just replace the wiper arm ! Replacing wheel boxes is more involved; I sometimes think the XJ saloon was built around the wiper boxes and the heater unit. (Only kidding !!!)
The Lucas wiper system in use from the 50s onwards, uses a rack cable inside a tube that is pushed to and fro by the wiper motor. Each wheel box clamps onto the rack tube and has a spindle with the cog at one end engaging on the rack, and the other end has a soft-metal spline piece on which the blade fixes, some have a bolt to secure, some are just push on. I can't remember what the XJ6 has but it is unchanged since 1968. Replacing the wheel boxes involves taking off the dash top as I remember it, as they are inside the car, whereas the motor is in the engine bay.
Of course I have them.. And the wheel boxes too, should the need arise...
Just give me an email or a call, I'll be glad to help...
David
EverydayXJ.com
704-796-9902
davidboger (10-22-2011)
al_roethlisberger
09-11-2015 10:04 PM
KarimPA
09-03-2015 07:32 PM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
