Replacing corroded fuel pipes above the IRS.
Dear friends, before I install my overhauled IRS, I would like to replace the fuel pipes that have corroded over the past 34 years. I do not think they are leaking fuel yet, but are quite badly rusted. I see that SNG Barratt no longer supply these and I am asking for advice. Will I need to dismantle them one at a time and go to specialist and have them fabricated to pattern, or is there a supplier known to the forum who may be able to supply new ones?
Any advice would be very welcome.
Kind regards, Danny.
Received 2,676 Likes
No supplier AFAIK.
I did this recently. Not becasue they were rusty but becasue I needed the fuel line to run down the LH side instead of the RH side in a AJ16 conversion.
I simply used 3/8 coated steel fuel line and removed the T fitting with a brazing torch and cleaned it up with some wire brushes. Then I used the old line as a mirror template and re-brazed the T fitting and couplers on the new lines where necessary. I used OATY 95 flux and silver solder. This is the only flux I found that works well on steel lines.
Ends were flaired or beaded as necessary using this ...
https://www.holley.com/products/plum...s/parts/008ERL
...and OEtinker clamps make for clean and safe hose connections over beaded ends.
https://oetiker.com/en/Products/Clam...ngs/Ear-Clamps
DannyRobertHoward (01-04-2018)
Knightrider
10-14-2014 11:38 PM
weisberg
04-28-2014 03:22 PM
cbomb
09-14-2008 12:39 AM
