Is this the right head?
Received 10,871 Likes
Received 2,626 Likes
The short answer is no.
While this cylinder head will most likely fit your engine correctly, the condition of the head will require additional machine shop work to reduce the possibility of a leaking head gasket.
Without a closer view, the area of the headgasket mating area around the no. 6 cylinder and timing cover appear to be corroded or pitted. If there is substantial pitting of the surface, additional aluminium will need to be welded to the head to fill in the areas of corrosion and the head machined to make the surface smooth again to reduce the possibility of a blown headgasket or coolant leaks.
If the camshafts are from a carburetted head, they cannot be used with your '84 XJ6 having EFI as the cam lobe profiles are incorrect for that application. In addition, the correct cams and tappets will need to be fitted and the clearances adjusted. Another area in need of attention on this head for it to work with a later XJ6 such as yours is installation of tappet hold-down plates.
In my opinion, it would be far easier to purchase a 'remanufactured' cylinder head that is ready-to-install and correct for your vehicle from a reputable vendor.
NBCat
NBCat
Benhamtroll (02-07-2012)
You may have already tried this, but I've found that having someone else pull the release while you strike the area of the bonnet (hood) just above the locking mechanism with the palm of your hand often does the trick!
You may want to check with Internet vendors for 'remanufactured' cylinder heads that come ready to bolt onto the block with the cams installed and valve clearances correctly adjusted. Motorcars Ltd and Jagbits are just two that come to mind.
NBCat
NBCat
extract from the advert
Apart from possibly not being a large-valve head, (which were fitted on Series 3s), the cam bearing caps are stated as missing. Looking at it shows it looks like a large valve head to me, but only measurement can tell you.
If you have a set of bearing caps they will not match to the head, as each set is machined with its head in the factory, so you would have to get a few thou off the caps, then get them bolted on and line bored by an engineering shop that has the right machinery.
A dodgy purchase in my view.
There Are No Cam Caps It Has The Fittings For An Air Rail So It Must Of Came Off A Car With A Fresh Air Pump I Believe These Have The Larger Valves And People Put Them On Earlier Engines
mikiep
12-20-2019 07:37 PM
X308XJR
05-20-2019 06:50 PM
