right volts
Received 10,873 Likes
That's a bit low, yes.
Jaguar did not specify particularly high output alternators for these cars so if your "13" reading is taken with a bit of a load....for example, a/c blowers blowing and headlights on....that might be about as good as it gets.
OTOH, if "13" is all she can muster with low or minimal load, I'd have the alternator and/or battery checked as well as checking all related wiring, cables, and connectors. There have been some cases where the alternator output wire develops excessive resistance.
Agreed with everything Doug said and just to add, a voltage drop test will tell you how healthy the cable is. With the engine running put one lead at battery positive and the other at the alternator output. Anything more than a few tenths of a volt shown on the motor would indicate a bad cable.
NTL1991
XJ40 ( XJ81 )
09-20-2015 06:22 PM
