Rough idle at start
I have a 1981 XJ6 with fuel injection. It starts fine but idles rough and at about 400 to 500 rpm for 4 minutes then it goes to normal idle about 800 rpm and runs good. I can't believe it is the cold start injector it is always 90 degrees here. Any suggestions. Thanks,,,,,,Jerry
Received 10,936 Likes
The 'could be' list might get long. Here are some starters
Might be.....
XJ 6 Series III 4.2 - Cold Start EFI Overfuelling
Might be that your AAV isn't working. This is what increases idle speed on a cold engine
Descripton and Function of Aux Air Valve, Series III XJ6
Might be that your coolant temp sensor is skewed. it plays a major role in fueling until coolant hits about 160ºF
Testing the Coolant Temp Sensor
Might be.....
Andy Paine (10-13-2018)
Received 2,399 Likes
I checked the AAV as described and it is closed when cold and closed when it get up to temperature, I also checked the plug and it does have 12 volts when running. I guess it is bad. (enclosed are pictures with engine cold). I guess I should remove it and try to clean it. Is the 2 allen screws the only thing holding it to the water rail? Thanks for the help.....Jerry
