Rust solutions
So I (like most sIII's) have rust that has come up from underneath the windscreen and the rear window as well. I have removed both and grinded them down to bare metal. I do have a couple spots where it has rusted all the way through. The holes are too small to put a metal plate in to weld it up.
I am also on a bit of a budget, however I dont want a budget fix that will haunt me later. So would bondo be sufficient or is there a way to have it spot welded? I cant afford to have it leaded otherwise that would have been option #1. Any advice would be great!!
just make sure the bare metal is treated. Then you can bondo, fiberglass, etc.
Of course metal is preferred, but with such a small area just about any repair will suffice.
There are MANY metal bonding adhesives so that you do not need to weld. You can check those out before paying someone to weld.
Rust is one thing but how do you prevent water from 1. entering the engne bay and 2. puddling in the area that the wiper motor sits? I have tried to find a drain hole I can unblock but ended up drilling a hole to make sure it drains. Not the best solution to drill holes in a rust-prone car. Any answers please?
mikiep
12-20-2019 07:37 PM
jimforrest (uk)
02-28-2019 06:42 PM
