Rustbucket XJC restoration
Anjum,
Well enjoy the ride and climb that mountain just becasue it's there. No shame in that. My first coupe was just as bad as yours so I'm speaking from experience. This was how I learned and since it was such a basket case I had no fear making major alterations.
I recently acquired a completely solid and all original coupe with 43k miles. To me it's a historical document. The gaps and panel fit are flawless and like no coupe I've seen before. The other 5 coupes I've had were all rusted or had major rust repair and the panel fit was just not there. Since I'm a modifier by nature this car make me uncomfortable.
Just for discussion, If I was in you situation again I would buy a solid series 2 or even a 3 sedan and transfer the doors, the roof and rear 1/4 panels. It would be quicker. Reinforce it while I was in there and had it all open. Series 3 would be more difficult as the windshield rake is different. This space would be an opportunity to fit the XJS convertible's window seal and perhaps quell the endless wind noise associated with the leading edge of the coupe's windows seal.
Appreciate the thought anyway and really like what you did with your XJC. I'm going to put some sort of tubing/ reinforcement inside the sills like Fiboys and yours but I haven't designed it yet, what size and thickness of tube did you use?
I will probably do your window motor conversion as well.
Do these MODs, jag did them for a reason on the XJS and keep in mind the XJS was an evolution of the XJ coupe.
![](https://cimg1.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/800x597/bodywork002_zpsfc96e972_9ced1481cc29f0e273863c5afcb41a3262b41bc1.jpg)
Amazing. I forgot how terrified I was of rust.
Glad to see you are not.
This makes us think long and hard about what to do with our second XJ12C shell, which we have currently labelled as "for scrap"
We'll be really interested to see your work on the floor and the bottoms of the quarter panels...... thats where our "parts car" is the worst.
The floorpanels are still available, albeit for the long wheelbase which will need shortening by cutting a strip out of the middle of about 4". These are a relatively simple cut out and fit if all the panels around are sound.See Elinors thread for some very helpful details. The chances are that at least the toeboard s are rotten but these are available as well. You can either drill out the spot welds or cut out and weld in a patch on the lower edge where it connects to the floor.
The bottom of the rear quarters can either be shaped out of new metal, or could even be cut out of a door and a lip bent on the bottom edge(four door please!!) and a section of arch formed, or bought and adjusted welded to it.
There is a complete rear wing for a coupe on e-bay at the moment.
If that's the major rust on the shell, as I said in your thread, it would be good to either restore or sell the shell on to someone to restore. as they are so rare.
If only you were in the UK....
Sorry to through cold water on you but that car is a gonner! IT's rusted and has thin metal in all the major stress points. The chassis may have settled and flexed so few of the seams will ever look right. If there is that much visible rust then there is probably much more you cant see in the rear frame rails, sills, under the rear seat, and the rails down the center of the transmission tunnel.
I hear what you are saying, (psst!! better not tell Stig that!!) I bought a rusty cheap one deliberately so I could strip it, weld it properly and improve it.
With so many "restored" cars the underlying rust and weaknesses are not addressed properly and show themselves a few years later. So it was a choice between buying a "decent" car and not being confident in what had been done, a fully restored by a known professional restorer, or someone on one of these forums, which would have cost me a fortune (and I still wouldn't trust a "professional" unless I knew him personally) or buying a heap that needed everything doing.
What icsamerica writes is absolutely correct in particular as regards my Jaguar.
It should have been scrapped.
But now it will be brought back to life. Because I had spent too much time and money on it before I realised it should have been scrapped.
Regards'
Stig
ronbros (12-07-2016)
