S2 hazard light flashes when LH indicator selected
Hi I have a strange problem with my s2 XJ6. I fitted a new hazard light switch (S3) and everything works as required but the hazard warning light flashed with the LH indicator warning light when the LH indicator is selected. RH side is fine. Im not too sure if it was doing this before I fitted the new switch or not. The car isn't on the road yet. Just trying to get everything working.
Any idea's??
Thanks in advance..
Any idea's??
Thanks in advance..
Dont worry guys I got it sorted!!
Only the rocker on the old switch was broken so I installed the new switch rocker onto the body of the old switch and all works fine. One of the contacts on the new switch is bigger than the rest. Looks like it is touching the contact next to it and hence causing the problem.
rsa760041
23
09-25-2015 01:33 PM
