S2 XJ6 boot lid not staying up.
Old 11-16-2012 | 04:37 AM
MJG's Avatar
MJG
Default S2 XJ6 boot lid not staying up.
Hi my boot /trunk lid on my jag keeps closing on my head.
Any experience with the cause and solution for this problem??
Thanks.
Michael
Old 11-16-2012 | 05:02 AM
fredd60's Avatar
Default boot lid
Broken or disconnected springs?
Old 11-16-2012 | 07:01 AM
Your down here, A BROOM HANDLE, and a CRASH HELMET for the scone.
Some S2 had coil springs on each hinge, and they go off, and get weak, boot lid sag follows quite quickly.
Others had a twin torsion bar arrangement up under the trim panel under the parcel shelf, same fault and end result.
JagDaim in Melbourne used to have rebuilt hinges on an exchange basis, but that was maaaaaany years ago. You will need to identify "coil springs" or NO coil springs first.
Old 11-16-2012 | 04:56 PM
MJG's Avatar
MJG
Yea she has coil springs. Looks like there both still connected but must have lost there spring. I will give Jagdaim a try. Thanks
Old 01-27-2013 | 04:55 AM
MJG's Avatar
MJG
Hi still no luck with the boot lid springs. Has anyone tried retrofitting gas struts before??
Old 01-27-2013 | 07:28 AM
Jose's Avatar
I suppose you can fit gas struts, Jaguar XJ-40 and later came with struts.
Old 07-16-2014 | 10:51 PM
Dasher Dave's Avatar
Hi, How did you get on with replacing the springs? or did you retro fit some gas struts from an XJ40? I have the same issue and I was considering the retro fit idea!
99xk8guy
06-05-2023 07:28 AM
H20boy
07-23-2021 10:39 PM
rusty37
04-05-2020 08:40 PM
GordoCatCar
01-02-2017 02:10 PM
prettydaim
09-07-2015 06:16 PM
Quick Reply: S2 XJ6 boot lid not staying up.
