S3 AC condensate drain
Memory??
There are 2, under the car, in the forward section of the trans tunnel. One each side.
You will need to LOOK carefully, poke around a bit, as some are near flush with the tunnel panel, while most protrude about 1". Usually full of muck, so best to actually find them, and poke them out.
Received 10,873 Likes
Grant Francis (07-30-2020)
