S3 Rear motor mount
Old 03-02-2020, 08:28 AM
quartetchiang's Avatar
Default S3 Rear motor mount
Do you see anything wrong in this picture? S3 4.2 rear motor mount.
Old 03-02-2020, 07:56 PM
Received 10,592 Likes on 6,996 Posts
YEP. Cotton Reel is uninstalled.
Have a read. It is V12 to start with, the 1./2 size engine is further down.
Still clear as mud, ask, I/we can walk you through it.
Doug (03-02-2020)
Old 03-02-2020, 11:34 PM
Doug's Avatar
Received 10,989 Likes on 7,216 Posts
Plus the two rubber blocks are sagging
Grant Francis (03-03-2020)
Old 03-03-2020, 09:00 AM
And my question is, What might have caused the two rubber mounts to sag? This geometry surely will cause the prop shaft to go out of phase, right?
will the missing cotton reel cause the sagging?
Old 03-03-2020, 09:24 AM
Dear Grant Francis:
Fun read!! Some digestion needed though on my part. Trying to picture my BW 66's arrangements.
Old 03-03-2020, 09:25 AM
Received 9,472 Likes on 5,471 Posts
Rubber sag is usually, but not always, caused by Great Age, heat and accumulation of escaped engine oil and road grime.
Old 03-03-2020, 10:06 AM
Dear Grant Francis:
By "cotton reel", are you referring to #3 in the diagram?
Old 03-03-2020, 04:29 PM
Jagboi64's Avatar
Received 3,222 Likes on 2,118 Posts
Yes.
Old 03-03-2020, 06:19 PM
Dear Grant Francis:
Its like Lego for Adults.
Over complicated, 99% assembled WRONG by someone, and usually parts missing.
I am trying to find a parts drawing of the assembly, but not enough coffee yet,.
Old 03-03-2020, 06:24 PM
As Elinor said, OLD AGE, just like us humans.
Out of phase, NO, out of alignment, YES.
NO, the mis-fitted cotton reel will NOT cause the sagging. Other issues, vibration, banging, rattling etc etc, YES.
LnrB (03-03-2020)
Old 03-03-2020, 06:37 PM
Dear Grant Francis:
"vibration, banging, rattling" --- I have precisely all those!!
Do you have a diagram of the BW66 version assembly? I do not have the factory service manual. And per chance that I had a glance of it, it did not seem to be very clear. Also the assembling instructions were rather vague. It'll be great if the diagram comes with part numbers attached.
Old 03-03-2020, 11:31 PM
Jagboi64's Avatar
Jaguar has parts diagrams available on their Classic parts website. Here is the XJ6, the 4.2 transmission mount is on page 46: https://parts.jaguarlandroverclassic.../gearbox/#p=46
The 3.4 mount is different, and on the previous page. Numbers in brackets after the part number on the drawing indicate quantity.
Old 03-04-2020, 02:29 AM
OK, 6 beers down, and I have included the 6cyl (1/2 size engine) in the Transmission Doco.
Had it done at 2 beers, but Cyber Space stole the damn thing, so I wrote it again.
anjum (03-10-2020), claudesr (10-30-2021)
Old 03-04-2020, 06:24 AM
You guys are ferociously fabulous!!!
Grant Francis (03-04-2020)
Old 03-08-2020, 04:50 AM
Dear Grant Francis:
Can you verify the error in the TH400 drawing being #27 and #28 should be reversed? Also, Some mentioned that the spring itself is directional, that it can only be one side up. Can you verify this?
Paul
Old 03-08-2020, 05:15 AM
YEP, #27 and #28 are in the wrong position.
The V12 mount has ONE "sleeve" as a machined section of the "pin", so then the washer, followed by the spacer.
The 6 cylinder "pin" is basically a BOLT, and so you have e spacer/washer/spacer.
SIMPLE
The spring is NOT ended. It will fit either way, BUT, the V12 has only ONE rubber seat on the bottom, the 6 cyl has a rubber seat on each end of the spring, AND, the V12 and 6 cyl springs are NOT the same.
claudesr (10-30-2021), Greg in France (03-08-2020)
quartetchiang
02-20-2020 04:58 AM
littlehandegan
01-02-2020 08:10 PM
PeteK812
07-21-2018 04:26 AM
plums
11-23-2012 01:33 AM
Quick Reply: S3 Rear motor mount
