Seeking submerged pump mount
On draining my defective right tank I found the retained submerged pump mount and fuel feed assembly had been repaired by a previous owner and the welds were failing. It seeped fuel at the slightest provocation. My welder shop guy has spent no small amount of time attempting a repair but the metal is so thin it burns through. I am desperately seeking a good used piece, as it only comes with a submerged pump, which I don’t need. It’s the right hand version of the attached drawing from the parts catalog, mirror image of the illustration. I know I should post to the classifieds, and will do so as well.
Please PM if you have a spare.
Received 2,399 Likes
Solution
Every single breaker / yard / used parts seller blew me off. I suspect getting into an old fuel tank was too much trouble; can’t faul them I guess.
‘Anyway my welding shop came through for me; fabricated a replacement out of stainless at no small cost, but it’s worth it.
‘The astute will notice the addition of a second return/equalizer line inlet, as the car was changed previously to an external single pump.
‘Thanks for the advice; I have to go get a little greasy.
The following 3 users liked this post by 4catstudio:
SableXJ6C
11-26-2012 07:07 PM
