Seized 4.2 S1?
Seized 4.2 S1?
I came across a 1972 XJ6 about a year a and a half ago, hadn't run since 2005 or so, I've done some minor tinkering but about 3 weeks ago I put marvel mystery oil in the cylinders and let them sit, hoping to generally promote lubrication. Today I took that battery out of another one of my Jaguars and hooked it up via jumper cables and decided to see if I could get it to turn over. I took the plugs out and popped the key briefly into the start position and just got a metallic clunk, repeated twice and stopped. The lights and such worked so there was at least some current although the amp-meter was at the bottom of its range. I guess what I'm getting at is, is it probable that my engine is seized?
I suppose my next course of action would be to try and manually crank the engine?
I read that it's a 33mm, can anyone verify this?
Thank you in advance for any advice!
British_Atlantic (11-04-2018)
