Ser III XJ6 to V12 project
Received 2,399 Likes
LnrB (09-30-2015)
Received 10,876 Likes
I meant to mention that, when pulling the engine, I inadvertently left just *one* item connected. A heater hose. That's a record for me. Usually I find that I've left two or three !
#30
#31
550 Maranello.
Alternator repair....which is about as far as I go on modern-ish Ferraris.
Very nice car. Quite fast, very comfy, a pleasure to drive, built like a tank. Lacks the 'wow' of the boy racer type Ferraris but I'd own one in a minute. Still reasonably priced on the used car market, too....at least for the time being.
Flint Ironstag (11-03-2015)
#32
Still making incremental progress. Bit by bit I'm checking items off the list.
Most recently I removed the 6-cyl fuel injection harness and installed the V12 harness...the latter being monumentally larger and more complicated than the former!
Removing/installing the harness is a fair bit of work. From the trunk/boot the harness travels forward into the cabin, downward toward the floor, and then snakes thru a blind tunnel where the rear seat cushion sits. On exiting the tunnel it travels forward along the transmission/driveline hump and eventually exits the cabin, and enters the engine bay, via a hole that is located just below the level of the battery tray.
The task involves pulling back several sections of glued-down carpeting...which is no big deal. However, the harness resides beneath several long sections of heavy sound-proofing ....also glued down. *Very* glued-down. It broke my heart but I had to slice thru the sound proofing to extract the harness. I'll use tape and glue to sorta restore everything back to original form and function but, naturally, a person hates being destructive. In this case, though, there was no other way. The glue was simply too strong and wouldn't let me carefully pull the sound proofing away from the floor.
The old harness pulled thru the blind tunnel easily but installing the V12 harness was a difficult. The ECU connector is about 6" long and slides thru the exit hole of the tunnel only if positioned at exactly the correct angle. After more than an hour of frustration I finally threw in the towel and used my Dremel tool to enlarge the exit hole.....and was then able to snake the harness through in about 9 seconds.
Prior to all of this I re-taped most of the harness and repaired any obvious faults. Much of the harness had rotten cloth covering which turned to dust when touched. Using Scapa cloth electrical tape gives a very nice appearing result, looking less cheapo than the usual black vinyl electrical tape
http://towzatronics.com/wp-content/u...Cloth-Tape.jpg
Mopar Dodge Plymouth Wiring Harness Black Cloth Automotive Electrical Tape | eBay
So far I've found only one circuit....fuel pump....that is significantly different between 6-and-12 cylinder applications but it'll be an easy matter to change.
#33
Received 9,220 Likes
#34
Yup!!!
I was in that area when doing my lumping. As a lot of that wasn't needed, that part of the Jaguar harness is till riding around.
Main difference: The Jaguar ECU is n the boot. The GM PCM
is in the engine bay.
That opening under the battery tray was/is a challenge. but, I managed.
The one/s in the tunnel: Lost that one. Wired around those. It works.
Even the Trip computer!!! Given odd input, it's output is odd!
The passenger cheek panel and scuttle are open at present.
Speedo wire redo? In the spring!!
Glorious recollection: It fired! Open exhaust. Yoweee.
Just had an interesting discussion with the Shop Foreman of a SMOG shop. They have political issues as well.....
Carl
Carl
#35
#36
Debbiesidera (12-06-2015)
#37
#38
Doug (02-02-2016)
#39
#40
The mounts themselves, and the mount brackets, are V12 specific. Fortunately the brackets use the existing holes in the sub-frame so the basic installation is indeed a 'bolt in'
