Series 1 Instruments
They should just unscrew off, after all there is no other access to the internals. They screw onto short "ramps" pressed in the case, so only a few degrees movement gets them off. There will be a sealing rubber ring, so tread carefully. If it were me I might run a bit of WD40 into the seating area to "persuade it" to come off, and not damage the sealing rubber.
There is nothing to grip onto, BTW, so some rubber gloves or something to grip the bezel will be necessary
XL391 (11-07-2015)
heroooo
11-06-2015 10:44 PM
Tim H
11-06-2015 10:37 AM
Mudder
11-04-2015 05:44 AM
