Series 111 trunk lid springs
Old 09-07-2015, 12:08 AM
prettydaim's Avatar
Default Series 111 trunk lid springs
Hi All , Can anyone advise where to purchase new trunk lid springs for my 1986 Daimler V12 VDP as the lid has become heavy and goes only half way up.
Old 09-07-2015, 01:42 AM
yarpos's Avatar
Received 2,098 Likes on 1,264 Posts
Where are you? or are you just wanting to purchase online?
prettydaim (09-07-2015)
Old 09-07-2015, 06:57 AM
prettydaim's Avatar
I am in Victoria Australia, I am also happy to purchase online,Regards John.
Old 09-07-2015, 06:59 AM
prettydaim's Avatar
In Heathcote.
Old 09-07-2015, 07:38 AM
Jose's Avatar
Received 2,451 Likes on 1,845 Posts
you might contact David Boger at Everyday XJ for good used parts.
he dismantles Jags and sells parts to all of us, and worldwide.
Everyday XJ
Old 09-07-2015, 10:52 AM
JagCad's Avatar
Received 2,399 Likes on 1,880 Posts
Jose:
That was going to be my suggestion. Freight might be the only down fall.
Imaginary alternatives:
1. Restore the "spring" by a heat and quench process.
2. Redo he mounts for hydraulic units.
3. A broom handle to prop it up, or a more elegant swinging rod.
Carl
Old 09-07-2015, 11:54 AM
Jose's Avatar
Carl,
Postal Service is not so expensive to Australia as it is to UK. But yes, cheap it is not.
he could also research salvage cars locally.
curiously, I've never had any trouble with the boot springs, wonder why he is having trouble.
Old 09-07-2015, 03:17 PM
prettydaim's Avatar
Thanks , I asked a jag man who has had the same problem and he told me the springs get weak as they are under tension when the lid is close which is most of the time unlike other cars where the tension is off when lid closed,although I have had no trouble with my 81 V12 sovereign owned for many years,Cheers john.
Old 09-07-2015, 05:16 PM
jagent's Avatar
John, Since you're in Victoria try Jag Prestige Spares in Ringwood or JagDaim in Moorabbin. Both are major Jag wreckers and they freight worldwide. In your case freight will be a whole lot less than importing foreign, plus you'll be sourcing from RHD cars (not that it should affect boot springs!)
www.prestige-spares.com.au
www.jagdaim.com.au
Cheers,
GordoCatCar
01-02-2017 01:10 PM
bigblackcat3
XJ40 ( XJ81 )
09-14-2015 04:03 PM
findre
09-10-2015 05:46 PM
Darrenmb
09-09-2015 09:31 PM
prettydaim
09-04-2015 09:13 AM
Quick Reply: Series 111 trunk lid springs
