Series 2 Dash Warning Lights??
Break warning
This is the brake Warning light. It's hooked up to the pressure differential block on the frame rail below the master cylinder and to the fluid level sensor. It normally comes on when the shuttle valve offsets because of a difference in pressure between the from and rear fluid brake circuits or if fluid is low. If it's on all the time check the fluid and fluid level sensor.
99xk8guy
06-05-2023 06:28 AM
