Series 2 front discs on series 1 xj6?
Does anyone know if i bought xj6 series 2 vented front brake rotors could i put them on my series 1 xj6? Could you use a spacer in between both sides of the calipers to give more room for the extra width of a vented disc like people do for the rear brakes. Thanks
Matt jag xj6 (02-26-2016)
Received 3,939 Likes
Does the master cylinder need changing or will the series 1 master cylinder work fine with the series 3 calipers? And one last question and i'll leave you in peace. Is the rear brakes on non abs xj6 series 1,2 and 3 the same? Calipers and rotors? Thanks again you have been very helpful.
Matt jag xj6 (02-27-2016)
The Only XJ Series 3 to ever have ABS was the 90's XJ12, those are rare and I've never seen one in the flesh. As for the rear brakes there are many differences from series 1, 2 and 3 relating to how the caliper mounts to the diff and routing of the pressure lines and how the exhaust hangs. Size and effectiveness is all the same until Jaguar changed to rear outboard brakes on the last few years of XJS. That setup is drastically changed for ease of maintenance, cooling and braking force.
Kopi
02-19-2016 08:41 AM
