Series 2 viscous fan coupling . . .
Received 10,933 Likes
Hard to say. "Iffy" at best.
Your's probably has the non-thermal fan clutch (easily identified by a single bolt in the center) that is "engaged" until a certain RPM is reached...at which point it starts to slip.*
I wouldn't trust that the Jaguar fan blades can tolerate too much engine RPM with everything welded up.
In fact, a pal with an early Ser III XJ6 (same fan and clutch as the Ser II) lost a metal fan blade a couple years ago. It wasn't a pretty sight. His radiator, that is.
* As oppsed to the later thermal-type clutch which sorta free-wheels until heat makes it solidly engage
ohhh i understand, yes it is a single bolt then i bashed it off to come out, it was making a horrible noise at high revs which is why i took it off because it was stuffed, but when i went to take it off the bolt was loose as and i undo by hand.
could you explain how this type of coupling works?
could that noise i was hearing horrible noise be because the bolt was lose? how can i test my coupling?
I assumed the coupling was like modern day cars and thermal type and even with the bolt lose i held the fan and wiggled the coupling and it had a little bit of play in it thats why i thought it was stuffed. when i took the coupling off i look on the inside which sits on the waterpump pulley one side has horrible wearing marks, like a main bearing been run with no oil. can take photo if you dont get what i mean. im thinking the noise i was hearing was the actual coupling slipping on the shaft/pulley for the waterpump not the fan coupling inside
It sounds like the centre bearing in your fan has siezed quite common for this type.
I would go for an electric fan 14" or 16" with a dial in thermostat switch, and set the switch at one or two degres above thermostat temperature. Most car accesory places would sell these. Not too expensive and easy to fit. I use them on my race car with no problem. Just an idea....good luck Ray.
thanks and yeah was thinking about electric im just not keen to change it from factory as this car is perfect condition inside and out everything 100% factory and new condition so wanted to try keep it factory, plan to keep it for 20 or so years in original condition lol not sure how well thats going to go though :P.
but cheers for letting me know about the bearings, how do i go about checking if there ok or if it was just that bolt loose?
There is a small bearing in the centre of the viscous hub which the centre bolt goes thru to locate it to the water pump.
The fan and viscous hub should spin with slight resistence' test by poking finger thru centre if the complete unit spins you will feel that the bearing has siezed.
The bolt may have been slightly loose if the bearing was siezed which makes the lot solid. There should be a locating washer with small dowl pin between bolt and hub to lock it in place
It gets plenty hot here in Arizona. I run 2 electric fan in front of the radiator that are tied to the air cond. I use a larger "Flex-Fan" on the motor; also have another core on the radiator. (google flex fan) I can now drive it around the city in the summer with the air on and not get hot. make sure you keep the fan shroud, it's a must.
good luck gene
good luck gene
xjrjag
09-27-2015 01:53 AM
abonano
25
09-25-2015 10:43 AM
