series 3 4.2 dizzy cap wiring order
I feel like an idiot for having to ask this, but I cannot seem to locate a diagram showing how the ignition should be hooked up on a 1987 4.2. It is either all AJ16 or Jeeps upon further examination and I don't see anything in the linked electrical diagram, but perhaps I am just missing it.
I saw a video that refers to the front most cylinder as 6, which ends up plugged into the dizzy cap on the bottom nearest the screw, but I have no idea if this is right. I tried searching the forums but the keywords necessary bring up too many no-start and performance diagnosis threads.
I'm astounded I can't easily find a diagram
#1 cylinder at rear
Distributor turns counter-clockwise
Firing order 1 5 3 6 2 4
This thread has some pics
https://www.jaguarforums.com/forum/x...timing-191389/
sidescrollin (01-23-2018)
The following 2 users liked this post by motorcarman:
sidescrollin (01-23-2018),
studentper (01-24-2018)
Thanks but Idk where that really leaves me without pulling plugs, and turning the engine over by hand to TDC. Any idea where #1 is actually plugged into the distributor?
If the Haynes manual ISN'T correct (which, so far, we don't know) then you're no worse off than you are now
If the above picture is correct then you're good to go.
If the above picture isn't correct then you're no worse off than following an incorrect Haynes manual
In reality it makes no difference where you begin the wiring sequence on the cap so long as you start with #1 at TDC compression and follow the correct order and direction.
It just seems like a silly thing to be so difficult to find and I thought maybe I could quickly google it instead of pulling a plug and finding TDC on #1 but I guess that's what I will need to do.
I just got the car and haven't had it running yet. So if I get it back together and it doesn't start, I'll immediately have to question the ignition wiring and I thought it was worthwhile to try and get the correct answer to begin with.
Does anyone know whether the sequence will be the same on the 3.6? I have the manual for that but didn't want to assume.
The following 2 users liked this post by o1xjr:
Doug (01-25-2018),
sidescrollin (01-25-2018)
This ONLY assumes that the engine has not been dismantled since it left the factory OR that someone did repair it and installed the Dist Drive CORRECTLY!!!!!!!
Many people that rebuild the engines do NOT install the drive correctly and just install it any way it ends up.
I ALWAYS installed the 'offset' oriented EXACTLY as it was when the engine was originally built so the dist aligned correctly.
bob
bob
Forget Haynes. Follow Bob and Doug.
Or, now having the following:
1. Firing order.
2. Distributor rotation.
3. cylinder number from the fire wall forward 1 through 6.
4. firing order.
Determine the fire TDC of number one. Set it up from there.
Make a note, picture or diagram and save them for the future.
Carl
1. Firing order.
4. firing order.
Carl
Woznaldo
08-26-2015 03:45 AM
Mkii250
08-14-2014 04:34 PM
