Series 3 AC receiver drier
Old 06-06-2017, 04:50 PM
Saemetric's Avatar
Default Series 3 AC receiver drier
Which side does the receiver drier sight glass go when installed on car? It's the long tubular style. I've seen it on left and right side.
Old 06-06-2017, 04:56 PM
sanchez's Avatar
On all the cars I have seen, the sight glass is on the left hand side of the car.
Old 06-06-2017, 05:22 PM
pjprofili's Avatar
That's right - I mean correct. It's on the left. If you follow the direction of flow the sight glass is after the drier.
Old 06-06-2017, 08:03 PM
Saemetric's Avatar
Thanks, but need more opinions. In my Jaguar Parts Manual, the drawing of it shows sight glass on rhs. Does it really matter?
Old 06-06-2017, 09:04 PM
Received 6,327 Likes on 4,370 Posts
The receiver/drier is directional and should have an arrow on showing flow direction.
Old 06-07-2017, 08:30 AM
Saemetric's Avatar
Horizontal tube type has no directional info on it. Anyone have a good pix of theirs installed.
Old 06-07-2017, 08:37 AM
Saemetric's Avatar
Make note of the stock Receiver/Driers direction and remove it. Wrap the new Receiver/Drier with the rubber tape supplied and loosely install it on the Radiator Support making certain it is pointed in the right direction. The sight glass block should be on the rightside of the car. Keep the end caps on the Receiver/Drier until the last possible moment or it will absorb moisture from the atmosphere, degrading the performance of your new system.
This is from Retroaires website for XJ's. Someone's got to know the correct way.
Old 06-07-2017, 09:53 AM
JagCad's Avatar
Received 2,399 Likes on 1,880 Posts
Three differing ways:
1. Clarke's useful pictures. Not what is on my 83!!
2. My memory. When my car was DOHC powered, the AC worked. Great at times, at others, it took a siesta. I'm quite sure the dryer in place horizontaly, just in front of the top radiator support had a bubble LF, as seen from the driver's seat of my LHD car.
3. The "lump" kit from Johnscars included a new dryer. Mounted in the same place, in the same manner with the same connectors. I just went out to the shop and checked.
No bubble viewer. Markings as to directions? None visible as mounted...
Charging my system still on my ever growing task lists.
Carl
Old 06-07-2017, 05:32 PM
yarpos's Avatar
Received 2,102 Likes on 1,265 Posts
Picture from my 84 S3 (standard apart from heart transplant) rec/drier in stock location. Mine has no sight glass , but the fitting on the left side (from drivers seat perspective) looks like it might have been in on OEM piece. The other end is just pipe out.
Old 06-07-2017, 09:40 PM
pjprofili's Avatar
No idea why it says right - unless something changed. Mine is on the left ('87) - always has been, and the common wisdom (Google it) is that the sight glass should be on the output side - i.e. before the expansion valve. Trace your lines and see whether that's the right or the left of your car.
Regardless, if you're retrofitting with R134a the sight glass is not as good an indication of condition as it was in the R12 days, so don't sweat it. All it is is a window. Everything will still work regardless of where it's located.
Old 06-08-2017, 01:00 PM
Jose's Avatar
Received 2,479 Likes on 1,862 Posts
in my 1984 the sight glass is and has always been towards the side of the coolant tank, closest to the red relay for the auxliary fan.
Old 06-08-2017, 04:02 PM
pjprofili's Avatar
Right. I mean correct. That's on the left.
Old 06-08-2017, 04:50 PM
Saemetric's Avatar
Thanks everyone. Consensus mostly is the sight glass should be on the LHS of the car. My 87 is that way so I'll put the 82 that way. At least I'll be consistent. (The 82 was on the rhs but had been changed at some point)
Old 06-13-2017, 07:31 PM
Saemetric's Avatar
Follow up to original post. I had to install the receiver drier with the sight glass on the rhs. No choice here. In trying to mount it in proper location with 4 screws the ac lines did not properly line up withe the r/d. my early 82 must have a different condenser than later ones.
So some that said here their sight glass is on the rhs are correct. I think it depends on what condenser you have.
Old 07-01-2017, 08:20 AM
Saemetric's Avatar
Does it operationally make a difference which way freon flows through the drier.
Old 07-01-2017, 10:34 AM
I seem to remember fitting one backwards and using it that way for a decade or so.
But yes, it does make a difference. The "receiver" function refers to its role as a storage vessel. What comes out of the condenser enters the top, and the desired liquid portion settles to the bottom. This is picked up from a tube that goes down to the bottom--should be pure liquid. The sight glass is in the output side to confirm no bubbbles--pure liquid is being sent to the expansion valve.
The above refers to a generic receiver/drier, which is always oriented vertically. The S3 horizontal installation is a bit unusual. I don't know whether it retains the vertical separation if inlet at top, outlet at bottom, or not. If not (i.e. Jaguar decided to source an ordinary unit and install it horizontally), it will still work if the condenser is putting out largely liquid. In either case, the outlet should be the side that is seen by the sight glass, and this should go to the expansion valve/evaporator inlet. IMHO.
Old 07-09-2017, 09:54 PM
Saemetric's Avatar
As a follow up, I cut the old drier apart as I was wondering if the orientation makes any difference. On this type that is horizontal, I don't think it's as important as if it were a vertical type. In side is a desiccant bag and filter on outboard end (if installed with sight glass on las of car). If installed the other way the only difference would be the filter would be on the inlet side It still should dry the freon and filter it.
The following 2 users liked this post by Saemetric:
davidboger (07-10-2017), LnrB (07-10-2017)
Old 07-10-2017, 10:47 AM
pjprofili's Avatar
You beat me to it - I was planning on cutting up my old one to see for myself.
I still think that in theory the filter should be on the outlet - i.e. the sight glass end. As I understand it from various online discussions the purpose of the filter is mainly to prevent the desiccant from finding its way into the expansion valve (or beyond if any were to make it through the valve - doubtful though) in case the bag ruptured or something else caused the desiccant to break apart.
LnrB (07-10-2017)
Old 07-10-2017, 11:25 AM
Received 9,441 Likes on 5,459 Posts
The things I learn hanging out in car forums!
I never knew what magic was encapsulated in the dryer thingy, only that the glass warned of a low charge. I never had a dead one to cut apart either.
Thanks, guys!
Old 07-10-2017, 11:52 AM
JagCad's Avatar
Yup.
So much to learn from "necropsies". A plumber's pipe cutter could do this neatly.
Elinor: I'd guess that the local AC shop might donate an old one to cut open.
Carl
