Series 3 oil filter adapter/oil cooler question.
1987 series 3 with a 4.2 6 cylinder. I'm wanting to perform a compression test on a used engine that I want to install. The old engine that's out milkshaked itself. The used engine that I want to install has zero history. Both of these engines that have the oil filter adapter on the side of the block are setup to run an external engine oil cooler. Can anyone tell me if the engine oil cooler adapter is thermostatically controlled or is it going to flow 100% of the time? I've looked in the series 3 engine repair guide that my boss has but there's no mention of any oil thermostat in that adapter. So my plan is I want to mate the engine and transmission on the ground, install the starter, add oil to the engine and spin it over for a compression test. That is if I can prevent oil from gushing out of the external oil cooler ports on the oil filter adapter.
Received 10,871 Likes
Received 2,399 Likes
For the limited purpose of a compression test where no heat is involved, the cooler is unneeded. To assure oiling to the wear points in the engine, a simple loop plumbed in should do just fine.
Not sure if this is a full flow system or merely a bypass. f the latter, mere plugging the inlet and the outlet would suffice. but, caveat, if it is full flow, that would deprive the wear points of lubrication. not good.
For complete results, I'd suggest first the dry test, then the wet test.
Carl
Carl
There is no thermostat. There is an internal spring-controlled bypass that operates if the oil is too thick when cold--much like the similar bypass that dumps oil directly to the pan. The spring valve can be removed to provide a bigger internal bypass opening. It's then safe IMO to block the hose ports--3/4 inch copper water pipe cap fittings work well.
Doug (02-24-2018)
Thank you for all your input.
I actually have a couple oil cooler bypass "nubs" that were from an X300 engine which will fit inside the oil cooler adapter ports. All I need is either to put a rubber block off or a rubber tube to loop it.
I appreciate the information. I will report back on the outcome whether this car will be saved or not by having a worthy engine.
andyw
11-30-2013 02:28 PM
