Series I jack - What's it look like?
Old 03-13-2013 | 06:10 PM
trymes's Avatar
Default Series I jack - What's it look like?
Does anyone have any photos of the jack from a Series I XJ6?
Is it functionally any different from a Series II/III car (I presume not)?
Tom
Old 03-14-2013 | 12:53 AM
Johnny Bouncewell's Avatar
This is what I found in my trunk this evening. Looks stock but I'm sure others will chime in if its not.
Attached Thumbnails Series I jack - What's it look like?-p3133303_zps78db0712.jpg
trymes (03-15-2013)
Old 03-14-2013 | 07:29 PM
davidboger's Avatar
^ Yep, that's it...
Different from the Series 3 in the way that it cranks..
There should be a tool to crank the Series 1 jack also... (The Series 3 uses the lug wrench)..
The Series 3 also has a solid base that the scissors extend from, where this Series one slides one side on the ground for extension...
David
Everyday XJ
trymes (03-15-2013)
Old 03-14-2013 | 09:34 PM
trymes's Avatar
Thanks guys. Sounds like I should just seek out an S-III jack,unless an earlier one falls into my lap.
Old 03-15-2013 | 08:42 AM
littlelic69's Avatar
I think it unwise to use such a jack on ANY car that is more than 10 years old!! Get a proper hydraulic lift and use the much stronger suspension to lift the car . And do not forget the axle stands. I had a bad experience of creaking sounds coming from a jacking point whilst lifting a series 2. At the Annual MOT it failed on corroded body parts.
Old 03-15-2013 | 03:43 PM
trymes's Avatar
littlelic: I agree with you, and when working on the car, I always use a hydraulic jack. However, I still need something to carry in the car in case I get a flat. I'll be certain to give a close inspection of the jacking points before I use them.
Tom
Old 03-16-2013 | 01:55 PM
davidboger's Avatar
Here are some photos to compare the Series 1 jack (blue) and Series 3 (black) ... Also the tool used to screw the jack, and the different bags that they used to store them.
The Series 3 tool was used both on the lugs, and the jack...
David
Everyday XJ
Attached Thumbnails Series I jack - What's it look like?-img_5171.jpg   Series I jack - What's it look like?-img_5172.jpg   Series I jack - What's it look like?-img_5173.jpg
Ahabiam (03-17-2013)
Dave1109971
12-15-2015 07:16 PM
SD96XJ6L
11-05-2015 11:47 AM
LnrB
10-13-2015 01:45 AM
k-man
10-05-2015 09:09 AM
Quick Reply: Series I jack - What's it look like?
