Shock replacement
Received 10,989 Likes
You have shocks, not struts
The front are the same as most any other car. The rears require removal of the springs so there's more work involved
These should help give you a feel for the task, then post back if you have more questions
Front Shock Replacement
Rear Shock And Spring Replacement
Jag7651 (10-25-2016)
