Show off your steering wheel
#62
The differences are in the positions of the screw holes for the particular steering wheel that you are buying, so in other words, the steering wheel seller should have the correct boss for the steering wheel AND for the car.
You might check with Moss Motors UK or USA, since they sell steering wheels for Jaguar and obviously should have the boss.
if not, check with British Autowood in Florida, he sells steering wheels for Jaguar too.
you can measure the width of the splined shaft from one spline at 12:00 o'clock to the other spline at 6:00 o'clock using a caliper measuring tool, that way you can arm yourself with the correct info. when ordering the boss.
Woznaldo (08-29-2017)
#64
Good used Nardi wheels come up on Ebay all the time ranging from $100 - $150 or so. The problem can be finding the correct mounting hub to install 'em on Jaguars.
Some higher-end sports cars had Nardi wheels as original equipment. The true OEM Nardi wheels can run thousands!
#65
I believe it is the same boss as for a Series 2 and 3, but if not, the splined shaft is the same as for a MK-2 / S type, 420, or 420G / MK-X.
Jose (08-29-2017)
#66
