Here's something I'm working on. Based on the S57 wiring diagrams doc in the stickies how-to section.
This is going to be a S3 wiring diagram that siows the actual wire runs in the vehicle. You'll be able to select a component ( black objects ) and it will display all the associated wiring. Each component will have external views to help with identification of the part and internal wiring diagrams as well.
I know it's redundant. The Jaguar doc is excellent. But I like projects like this, and I have learned that I learn best when I rewrite the information that I'm using. I've already discovered a few things that I didn't know while building it to this point.
Biggest fault with all the other diagrams is the lack of the location of the Jaguar connections... shows they exist but not where they are actually located...
This was one of the reasons that I started this project. Physically tracing circuits is tedious at best and often the only way to find the culprit.
