SJ6 One Cylinder not firing
Hello: My 1990 XJ6 Soverign has one cylinder which is not firing. I have ruled out the spark plug, the spark plug wire (it's sparking with a new plug and I switched the wire with another wire), the injector and compression. I assume this leaves the injector electrical connector, the wire to the injector, and whatever controllers are before that which make the injector work. Any suggestions?
Lanny
Lanny
confused as to HOW he checked the injector in the cylinder that "is not firing".
Ohm'ed..switch injectors, etc?
