Slipping during turns and Oil Pressure Question
I am happy to finally announce that my series one is FINALLY running great. I have always had a charging problem and finally figured it out (a wire was disconnected from the starter relay). Runs and starts great now so I figured I would start tackling other issues. First, what is the proper oil pressure while idle and during normal, say 35-40mph (55-65kph), driving? Second, I have a problem while accelerating through turns where it feels as though the transmission or rear diff. is slipping. It seems to be only if I am giving it gas through the first part of the turn, while if I only accelerate out of it, I usually have full responsiveness. It feels just like my old truck (with a very worn clutch) does if I accelerate too hard, just slips and takes a while to gain speed, and when it finally goes back to normal, it catches hard. Only seems to do it during turns. Any help or advice would be great.
rustfreemike (08-29-2012)
...First, what is the proper oil pressure while idle and during normal, say 35-40mph (55-65kph), driving? Second, I have a problem while accelerating through turns where it feels as though the transmission or rear diff. is slipping. It seems to be only if I am giving it gas through the first part of the turn, while if I only accelerate out of it, I usually have full responsiveness. It feels just like my old truck (with a very worn clutch) does if I accelerate too hard, just slips and takes a while to gain speed, and when it finally goes back to normal, it catches hard. Only seems to do it during turns. Any help or advice would be great.
The BW model 12 transmission in your 73 is very sensitive to fluid level. From your description it's possible that around curves the fluid is sloshing around away from the pickup screen. I know this is sort of obvious but check the fluid level carefully - level surface, running, warm. Model 12s hate low fluid levels. It could, of course, be 1000 other things though, but at least that's an easy fix
I don't think the diff would be the culprit but maybe a malfunctioning pow-r-lock if your car is equipped that way?
~Mike
Civicalized (08-29-2012)
Awesome, thank you! I will check the level as you described. I'm not sure how level the car was last time I checked, so I will find a good spot to check it this time. Hopefully it is something that simple. I did have to top it off a few months ago but maybe I didn't get enough in there. As for oil pressure, mine sits at about 60 (give or take 5, according to my dash gauge) so I will check it with a manual gauge like you suggested. It is due for an oil change soon so I will try your oil mixture (20w50 with lucas oil st.) when I do. Thank you so much for your input, hopefully I have simple fixes!
To illustrate the Model 12 fluid issue... I bought a Series 3 E-type on ebay a few years back (V-12, Model 12 Trans). Went about 40 miles to pick it up and drive it home. Everything was fine until I was getting off the highway. Went around the exit cloverleaf fast (trying out the suspension - you gotta right?) and immediately went into a left turn lane and stopped, waiting for the green. When the light changed the E-type wouldn't move. After a couple of minutes of sitting there with the hood open fuming and wondering what the heck was going on I got in and tried it and it went back into gear. Got home, driving real easy and found that the fluid was low. Never had a problem with it again.
~Mike
Alright, sorry for the late reply, I have been busy. I topped off the tranny fluid and it seems to have fixed the problem. Kinda crazy how sensitive those things are (as illustrated in your E-type). I have watched my oil pressure a little more closely and it sits at about 60 while driving, and maybe 45ish while idle, after I have been driving. I wont worry too much about it until after I change the oil, which should be soon, and If it remains high, I will check it with a different gauge. Thank you so much for your help, My car seems to get more fun with each little thing I fix.
personally I stay away from any additives, they are mostly snake oil, I do use Castrol 20W50 oil and a Jaguar oil filter.
yes, Jag trannys are very sensitive to fluid level, they are after all, American made.
![Icon Eddie](https://www.jaguarforums.com/forum/images/smilies/icon_eddie.gif)
And just like the cooling system, these cars always require more fluids than it appears, so check it and check it until the cows come home.
![Icon Violin](https://www.jaguarforums.com/forum/images/smilies/icon_violin.gif)
BrentGardner
28
04-26-2024 03:08 AM
