Small Stumble
Small Stumble
Does anyone know where I should start looking for a small stumble. It only happens from a dead stop. When you press the gas is just stumbles a little. Kinda like it wants to quit. It has never quit though. I have a 1987 XJ6 with 82,000 miles and a 4.2L. Just did a complete tune up and changed my fuel filter. Thank you in advance.
Received 10,980 Likes
That obviously makes it more difficult to nail down. The 'could be' list might get a little long.
Clean the throttle body and, while you're there, carefully inspect the ducting from the Air Flow Meter to the throttle body. Is it loose, cracked?
Carefully inspect/clean/tighten all connections and wires to the AFM, coil, ignition module, and firewall relays
chtp66
05-26-2014 06:45 AM
