Spark plug helicoil
Spark plug helicoil
Today I removed the spark plugs from my S1 XJ6. One of the plugs came out with what appears to be a Helicoil still attached.
The thread in the head looks to be in good condition.
I have a few questions.
Can I just replace the Helicoil and if so how do I determine the size. Or is this a job best done by an expert?
Thank you in advance for your thoughts.
Received 9,440 Likes
Yes, Helicoils look line springs. The hole is rethreaded with a larger tap specifically for the that helicoil. If you put it on the new plug it might go in easier. But you'll want to put thread locker on first, so when it finally starts you can just screw it in and forget it until next time.
MalnFaye (05-09-2016)
mmschars
05-08-2016 09:14 AM
