Spectra Fuel Tank - Series III
Hi All!
I know there have been some questions as to the build quality of Spectra fuel tanks for our cars. I decided to take the chance after my right-hand tank completely failed and QuickSteel putty failed to provide a long-term solution. I'm proud to say that the Canadian manufactured tank is a stellar replacement for the factory Jag unit. The seams are identical, the material is actually a little more robust, and all mounting/connection points are perfectly placed.
The new tank even came with a new o-ring for the filler neck and a new gasket and lock ring for the float/sender unit. For $315USD, I consider it a great value. The only thing it lacks over the factory unit is the chunk of sound absorbing material on the outside. Anyone needing a new tank, I can't recommend these highly enough!
Received 2,263 Likes
Nice! Well they do one heck of a job. I do have ONE tiny complaint, though. In an effort to be helpful, they welded a nut on the rear bottom mount. This is a fantastic idea as getting a 15 mil spanner in that tiny bracket is a bugger... the problem was that they got a little crazy with the welder and filled the threads with spatter. Not a huge deal, about 5 minutes with a hammer and cold chisel broke the welds and I resumed mounting the tank with the original nut. Other that that one little flaw, I WHOLLY recommend the tanks. They fit like a dream, don't leak like my old one did and the filler assembly actually slipped right into the neck even with the new o-ring... no twisting, banging and cursing required. And hey, as it turns out, the previous owner put a Spectra on the driver's side so now my car matches again.
hen555
09-07-2015 11:13 PM
jagent
09-07-2015 05:00 PM
deanh
09-06-2015 08:20 PM
