Spewing gas from fuel rail when cold...
Literally spewing. Like, a fountain of gas.
I finally caught it in the act. Basically on first startup after sitting a few days, it will immediately fire up but the gas smell becomes quickly overwhelming. Pop the hood and there is gas spraying from all fuel lines on cylinders 3 and 4 and maybe cyl 2 as well. The car has a brand new cold start injector installed as well as six new fuel injectors.
If you shut it off, let it sit a minute or two and restart it, the gas slows to a drip, then eventually goes away. Hot starts afterward produce no gas. It's like there is too much pressure on the rail.
The short lines going to and from the rails and injectors all look good. Most were replaced when we replaced the injectors.
Obviously we can't have this because it's a major fire hazard, but what's the most likely answer! Is there a fuel pressure regulator not doing it's job? A special kind of fuel line we should have used? Unplugging the cold start injector changes nothing.
Jess
Jess
Received 10,989 Likes
Was fuel injection grade fuel hose used? It's a "must".
Are the leaks coming from the hoses you didn't replace?
Are the clamps tight? And correct clamps used?
Yes, there's a pressure regulator. But, if it was allowing the pressure to get too high, you'd have a running problem: over-fueling/flooding, black smoke, engine choking-out
One thing I can say is we had leaks before we replaced all the hardware, and leaks after. It's what caused us to replace the injectors and the cold start injector in the first place. I'm pretty sure we replaced old hoses that leaked with new hoses that leaked.
I'm beginning to suspect we used the wrong parts. What should we have used?
Jess
Sometimes the bodies of the injectors themselves will leak. I've seen it only once, but, still.
This seems less likely since you replaced the injectors.
I wonder if the fuel rail has some pinholes or something?
I think you're gonna have to wait till the engine is cold again and have someone start the engine while you carefully observe where, exactly, the leak is coming from.
Might wanna have a fire extinguisher handy. Or some dry heavy towels to smother a fire. Be careful !
What's maddening is, they were leaking BEFORE all the work, too. This car has always been hard to start while hot, which makes me wonder what's going on with the fuel pressure. All new injectors, clamps, hoses -- and it looked like the fountains at Caesar's Palace.
Jess
yachtmanbuttson (08-11-2020)
