Squeak Sound, HELP!
Generally speaking... belt squeaks on serpentine systems are usually a worn out idler pulley, tensioner pulley or A/C compressor bearing. I like to use a spray bottle of soapy water on the stream setting to place a judicious squirt in the place I suspect is making the noise. It will briefly go away if you hit the errant part. The soapy water dries quick and does no harm. Then replace as necessary.
You may want to head over to the Modern X300 forum as your particular questions are more pertinent there.
Firstly welcome to the Forum.
Your 1995 is known as an X300 in Jaguar talk. Might get more answers with a repost in that section.
However:
If that belt conditioner works, then I suspect either the belts, the multi V sections of the pullies (they fill with crud so the belts dont grip so good), or the rubber of the front crank pulley (harmonic balancer) is delaminating.
However:
Received 2,399 Likes
I have an opinion. Belt conditioner might quiet belt for a short time.
But, they hasten the demise!!
Not sure as to how that might work on a serpentine, but way back when, we used a bar of soap to silence squeaky "V" belts. Not long lasting, but not destructive, either.
I've noted that modern belts can look awful, function just fine.
Anecdotal. My first car had a flat belt to drive the fan only. loosing it was not a catastrophe, The T Ford cooled almost as well, as long as it was in motion!!! However, a popular accessory was a water pump driven by a longer flat belt. MY T's enjoyed them.... Simplicity wins !!!
Carl
Carl
FS[SouthEast]: 1995 Jaguar XJ6 Vanden Plas with 16" Lattice Wheels
reedjs
09-04-2016 10:13 AM
Jaguar Forums Editor
08-29-2016 05:16 PM
