Starter issue??
Starter issue??
Within the last week I’ve noticed some issue when starting. Used to just start right up. Now it’s playing some games. sometimes it starts right away tho. Other times I’m getting almost a pots and pants rattle like sound. I wait a few seconds after like 2-3 more cranks it starts but I do hear a slight rattle but goes away after a few seconds. I changed my plugs,oil and fuel filter on Friday. So curious as to where I should begin this journey. Shocks are going in soon but want to handle this 1st. Gents- your guidance and wisdom always appreciated.
Received 10,989 Likes
The starting problem may well be a different issue than the pots and pans noise. Or not.
To clarify, that starter is cranking the engine normally....but the engine can be hard to start?
Or .....the starter isn't cranking the engine normally?
A failing starter, if that's what we're talking about, can make some horrible sounds.
doghead08 (08-20-2023)
Thanks as always fellas. Here’s my deal. When I crank it for the 1st time of the day to start er up , it starts fine, maybe an occasional rattle after it starts but that only lasts for say 2-3 seconds. I go where I go, or do as I do and then shut the engine off. It’s that next attempt that it acts up. I’ll crank and its that pots and pan w a hint of grind. I stop cranking obviously and let it sit, may start right up after I crank again or after the 2nd or 3rd attempt.
I read a prior post about swapping the starter. Seems like a bridge too far for me to do. I took one out about 13 years ago but never had to put it back in (scrapped an 86 prior to buying a new one hoping to learn its guts) If my inner Doc Brown kicked in, I’d have filmed the whole scrap job.
Unfortunately I have to return this starter. It didn’t sit right when we installed it-wasn’t catching the fly wheel right. On a somewhat positive note - I I have 5 of the 6 shocks in. One of the front shocks I ordered was missing parts. Waiting on that as well. If all goes well - should be back on the road real soon.
Bill Mac (09-16-2023)
Don't take this wrong but are you sure it isn't stuck on the old starter, under some grease and grime? It's easy to miss. I'm 99.9% sure they all used the spacer; I've never seen one without it. It would certainly change the starter-to-flywheel meshing.
The following 2 users liked this post by Doug:
Bill Mac (09-16-2023),
Chris Scott (09-20-2023)
Turbo_dash
10-09-2012 06:28 PM
